cose 450 convertor problem
JoelS1
New User
Have a 1980 case 450 dozer with fluid poring out from bottom of torque convertor.Could this be a pressure issue?I dont want to take out the convertor if i dont have to.I would ppreciate advice
I had a 450B that got a crack in the torque converter . Your's could be a seal in it . Mine was a job to pull out and replace. I had to pull mine about 3 times before I got it right.Test it with some air pressure before you put it back in . Had I done that I wouldn't have had to do it so many times.
