OC6 or 420C
Agman101
Been bitten by the small crawler bug for awhile now, have to scratch the itch. If you had the choice, an OC6 or 420C? Going to be integral for the farm - spreading, plowing, go up to 3-4 bottom vs 2 3pt now and 12-14'
wheel disk vs 8' now. land is damp, always the last to get out even with 4x4 and adding acreage yearly as well
you might be better off with the 420C as John Deere parts are around, I believe either thru a dealer or a good salvage yard. You may be able to get a owners manual and shop manual from "Jensales". The OC6 Oliver parts can be difficult to find I don't know of any dealer sources, possibly some salvage yards.
If I wanted a crawler to do some real farming on wetland - I'd want something a bit more modern that I could find parts for. Used to be many wide-track Oliver HGs in my area as little row crop tractors. Not for wet work though. The only crawlers I've seen in wetland farming are John Deere 350 wide-tracks used in black-dirt onion and lettuce farms in various parts of NY. I cannot imagine any Deere 420 with a 113 cubic inch engine pulling 4 bottom plows.
A 420 isn't going to pull more than 2-14's in most ground. Actually, you could probably pull 3, but in 1st gear! Sounds more like you want a 350 or 450 ag crawler. Finding an actual ag crawler with a 3pt might be hard, i don't know. PTO is easier to find.
An MC/40/420 is a nice crawler but you aren't going to pull much more than you are now, certainly not in 2nd or 3rd gear. Whatever you get, undercarriage condition is the #1 thing you have to look at. Throw a track in soft ground sometime and you'll know why.
And O C 6 will pull three bottoms as all it is is a Oliver 77 on tracks . And you best like LOW SPEED plowing . As i did my share of crawler plowing back in the early to mid fifty's . There would be three crawlers in the field at the same time One OC 3 , One OC 6 and one D 4 cat , two bottoms three bottom and five bottoms and no faster then a good walk . And at the cost of and under carriage you can buy LOTS of tires .
I pulled 3 16" bottoms with my 420 for years. Also an 8' disk with 4 railroad ties on it for weight, another one crossways dragging to smooth the clods, a grain drill seeding sudan and a roller bringing up the rear. I'm sure the neighbors thought I was a little nuts. This was back in the sixties when tracks for field work was unheard of.
A guy down the road bought an OC-6, why? He needed a live PTO. It also has more forward speed than the John Deere.
(quoted from post at 02:31:38 05/07/14) I pulled 3 16" bottoms with my 420 for years. Also an 8' disk with 4 railroad ties on it for weight, another one crossways dragging to smooth the clods, a grain drill seeding sudan and a roller bringing up the rear. I'm sure the neighbors thought I was a little nuts. This was back in the sixties when tracks for field work was unheard of.
thought that was when it was popular lol.
Thank you all for your input. I think it goes to show you find reason and will to go where you wanted anyway. How about mechanics? is there a preference? Aside from parts, a big aside I know, is either easier to work on, I do all my own wrenching. The Oliver looks "roomier" wide gauge and all. Also I came across an Oliver ad for the OC's and a fellow was plowing, right side track in the furrow. Is that right? I read in this forum never do that, plays hell with the machine, lots more wear, etc.I need some more education obviously
Parts for an OC 6 can be had from Zimmerman Oliver Cletrac in Ephrata PA. The engine is from an Oliver 77 tractor and the transmission from an Oliver 88 tractor. Landis Zimmerman is very helpful and knows all there is to know about the Oliver crawlers.
As was said, Zimmerman is THE source for Ollie parts. The OC6 is a lot more tractor than a 420. But 420 parts are available too, lots of people out there parting them out.
The 420 would be more comparible to the OC-4. I'd go for the OC-6 personally. Our OC-4 is a nice 2 plow tractor as is the 420. I certainly wouldn't overload a tractor that old with a 3 bottom. The OC-6 should handle a 3 bottom in good fashion.
OC 6 More power, independent PTO, live hydraulics, and some had 3-pt hitches. Engine and transmission parts same as oliver row-crop 77 engine/ 88 transmission. Crawler-specific parts available through Landis Zimmerman.
I dunno, any plowing we ever did with our OC-4 was in the furrow. Never seemed to do any harm. But then again we never plowed that many acres with the crawler, either.
