Need A Starter For Mini Excavator Komatsu PC25
Anonymous-0
I have a Komatsu mini excavator PC25 that I need a starter for, anyone know where I can find one, there are no numbers on it and everything on the excavator is in foreign. I believe its about a 1995, anyone have any leads
I did a search for it by the machine type, as well as by the engine type. That said, based on what I could find, it's probably a Denso. That being the case your best, and cheapest way out will be to simply find a rebuilder and have your old one repaired. If it's damaged to the point of not being repairable, any good shop can look at what you've got and get you another one just like it. If you don't have one at all, again, most good rebuild shops can look up the correct starter by the application (either by the machine or by the engine type) and get you one that way. Good luck.
