TractorLinks.com
Re: JD 350B power
PD Mechanical
05-07-2014 12:59:09
A little more Info please. Will the machine move at all now? If so it could be either reverser or steering as JDemaris says. Follow his instructions to pinpoint the problem. Quite often the steering clutches become oil soaked from leaking final drive or bevel gear seals. If it no longer moves at all, it is likely the splined coupling between the reverser and the transmission. If you have other questions or need parts feel free to contact me directly. Good luck. Steve. www.sadygerts.com
john jenner
05-07-2014 14:22:52
 Re: JD 350B power in reply to PD Mechanical, 05-07-2014 12:59:09
tractor moves fine. Just not much "low end grunt". Steers fine left but right, if I pull the lever and it is not full throttle, the dozer will actually stop. Seems to work much better if full throttle. Reverser seems to function fine with no issues. Hopefully this is what you needed. Let me know if more questions. Thanks so much for the recommendations
