I have pulled engine and bell housing to fix trans
pump leak and after pulling pump I noticed input
shaft has about 3/8 inch up down side to side play.
On parts schematic it shows that there is a ball
bearing on shaft that I suspect is bad. When I
drained trans oil I found a piece of ball bearing
cage in bottom of trans. Is there anything to pay
attention to or suggestions on pulling front cover
and top cover to access input shaft.
