TractorLinks.com
Re: JD 450 HLR input shaft
roy suomi
05-04-2014 20:49:27
I'd look at the pilot bearing for looseness causing a wallowing around of the input shaft.. Those input shaft bearings always get replaced when overhauling a HLR.. There's no fudging on that.. Engine main bearings loose will cause problems but it would have to be extreme to take out that bearing.. You can pry upward in the flywheel to check for crankshaft looseness, but usually the rear main seal will start leaking at that point.. The crankshaft shouldn't move hardly at all..
Mossback
05-05-2014 01:47:17
 Re: JD 450 HLR input shaft in reply to roy suomi, 05-04-2014 20:49:27
I'll check pilot bearing. Going to put new one in with clutch. Should I change needle bearing in rear of input shaft even if it seems ok?
roy suomi
05-05-2014 14:43:24
 Re: JD 450 HLR input shaft in reply to Mossback, 05-05-2014 01:47:17
Ya know what ?? If it doesn't break the bank , I think I would....
