First off, Thank you to this Forum as I have solved numerous problems with my old equipment with advise found here.
Now for the new problem, I have a 1973 International 500C Crawler and am having a problem with the two bolts on either side that screw into the center pin of the front idler. The bushings are snug (but have a little play from wear) and the bolts have a captive piece of metal on them that prevents them from turning. This leads me to believe that the center pin that the idler rides on is turning and backing the bolts out and in as I go forward and reverse. I have tightened them numerous times but just with an 1 1/8" open end wrench and they seem to back out within 1/2 hour or so. Anybody know how tight these bolts are supposed to be or if there is a step I am missing?
Thank you!
Hutch088
Thank you!
Hutch088
