JD 70 Skid Steer ??
dave404
the left side has quit pulling.
I can push the lever on the pump and jerks and kinda makes a grinding noise.
I cant find any info so maybe someone can help. thanks
The JD 70 is actually an Owatanna. It sounds like you have lost a pump and probably the motor. You will probably have to pull them out and have them rebuilt. Hopefully they haven't ground themselves up to the point where they can't be rebuilt.
If it is like mine JD 90 it uses a chain drive off of the hydraulic motor. Maybe it is a chain problem. Going by memory so I could be wrong. Between the wheels is a small inspection cover.
Here is a link to some parts. Just a page I found to give me a bit of a breakdown. Click at the top and it shows different breakdowns. Good luck.
http://www.waldochsports.com/pages/OemParts#/John_Deere/70_SKID-STEER_LOADER_WITH_UTILITY_BUCKET_%28MANUFACTURED_1972-1980%29_-PC1331/HYDROSTATIC_CIRCUIT%3a_POWER_TRAIN/13310002/1331C210C1805000004
It looks like the link works below...
JD 70 parts
