case 530 backhoe com
mite-help
I have a tractor that I bought as a project a few years back. the engine has been out of frame for a total of about 8 yrs. now, & have ready to install. what kinda problems can I run into with the com trans? unit has been covered with a tarp, towels wrapped around torque conv. think it will be worth a chance to install engine & try? worked ok til engine failure. thanks for comments.
change the COM oil and filters before starting, I recommend CNH Hy-Tran oil, as long as it did not get full of water setting it should be fine, also when installing the engine use the red 515 gasket eliminator cnh has works very well
thanks case nutty--someone had mentioned the ''paper faced plates in clutch packs'' exposed to air too long coming apart---not sure this unit uses this setup-at any rate, will flush, filter, fluid-give it a try-agree with you on fluid type.
that unit should not have the paper disc type clutch plates, I have gotten them in pieces and put them together after setting years and they still work fine today
