Hi guys,
While I'm waiting for my new injectors to arrive, I have been working around the property and noticed yesterday when I did my inspection that the right hand side track carrier roller shaft has worked its' way out of the housing. It's a first gen JD350, 1965. I thought these were pressed into the housing. What would cause this to occur? The whole undercarriage was new about 8 years ago, and has maybe 300 hours on it, new pins, bushings, rollers etc. Was about $8,000 worth from the bills I have from the previous owner. The track pins seem very stiff, I guess from being still new?? As you can see in the pic of the left hand side, which is fine, the tracks seem stiff. I have included a few pics of the failed shaft side, as well as a few of the general condition of the track so you can see if there is anything wrong in the wear patterns.
Can I just remove the housing and press this back in? What would be the correct course of action?
Thanks
Paul
This is the left side, showing how stiff the bushings and pins are.
Thanks
Paul
