JD90 Skid steer valve body
Brian Ski
I have a JD 90 and the valve body is leaking pretty bad. I took it apart a while back. Looks like a little sand got into it and scuffed one of the spool valves. I put it back together with a new seal and it is still pretty bad. Was told you can get them aftermarket. How do you cross it?? or where is a good place to get one?? I have several pictures of it when I took it out. Not sure about leaving it the way it is. Leaves small puddles where it is parked. It is a small older machine but works great for what I need.
