Yesterday's Tractor Co.
Shop Now View Cart
TractorLinks.com
Re: New issue with my JD 450c
jdemaris
04-11-2014 10:42:54
Sounds like all you have - ever - is the right track driving. Left clutch is probably no good. As to cost? As to fixing? Wet clutch Deeres cost a small fortune to fix. One reason why I'd never own one. Many shops will refuse to warranty unless all steels and fiber linings are replaced along with seals. Often an oil manifold is need. 8 steels cost $450. 8 fiber disks cost $640. Seals and piston cost $200. A manifold if needed is $177. Total parts: $1500 not counting new oil. Labor? One full day to be safe. If shop rate is $80, that's $640. so such a repair just for one side can easily run over $2000. Make sure you check the pressure to the clutch and make sure it's geting the proper PSI. Have you looked under the seat to make sure the linkage is working right and the hydraulic spools are going in an out?
