Yesterday's Tractor Co.
Shop Now View Cart
Re: New issue with my JD 450c
04-11-2014 04:56:02
To try and better explain...When I pull the right stick back the right side stops as it should. But my left side stops as well. I am not touching the left stick at all at this point. It should be moving and thus turning the dozer. This happens when I am on a hill facing up or down. On flat ground it seems to operate fine even with a load. I will check the stall test today when I get home. Does this sound like my left side clutch is bad? If so how much doe sthis cost to get fixed. Rough estimate....No way I can do it myself. No time and to scared LOL.
This post was edited by njthor at 04:56:57 04/11/14.
04-11-2014 10:42:54
 Re: New issue with my JD 450c in reply to njthor, 04-11-2014 04:56:02
Sounds like all you have - ever - is the right track driving. Left clutch is probably no good. As to cost? As to fixing? Wet clutch Deeres cost a small fortune to fix. One reason why I'd never own one. Many shops will refuse to warranty unless all steels and fiber linings are replaced along with seals. Often an oil manifold is need. 8 steels cost $450. 8 fiber disks cost $640. Seals and piston cost $200. A manifold if needed is $177. Total parts: $1500 not counting new oil. Labor? One full day to be safe. If shop rate is $80, that's $640. so such a repair just for one side can easily run over $2000. Make sure you check the pressure to the clutch and make sure it's geting the proper PSI. Have you looked under the seat to make sure the linkage is working right and the hydraulic spools are going in an out?
