TractorLinks.com
Re: 350c
jdemaris
04-10-2014 05:52:25
If the C has ever had a replacement adjuster - there will be two grease fittings. Are you using the right one? Is it a button-head? Also - how far out it the adjuster piston? If it near the end of its travel it will likely leak even if you put a new neoprene seal on the piston. I assume you have not messed with the pressure-release bolt and jam nut?
green meadows
04-10-2014 17:47:51
 Re: 350c in reply to jdemaris, 04-10-2014 05:52:25
Im not real sure I even put the grease in right place I put it in the button hole grease fitting it looks like a idler that is the only button hole grease fitting on that side I also didn"t mess with any jam nut or anything need advise I inherited this machine but I can run it but I don"t know about tighting the tracks need help bad threw a track one time and I don"t want to do that Again
