TractorLinks.com
Re: cat D7E engine balancer install
Bob/Ont
04-02-2014 17:52:33
Forget about the marks on the gears. Take the small square cover off the top of the flywheel cover. Put ANY piston on TDC, with balancer gears not engaged, turn the weights until they are down and lock them. Push up the gears and bolt bearing into place then remove the lock bolt.
The ballancers turn at twice the speed of the crankshaft. They always are down when any piston is on TDC.
Later Bob
Steven and Tonya
04-03-2014 17:52:38
 Re: cat D7E engine balancer install in reply to Bob/Ont, 04-02-2014 17:52:33
got it installed today just as you said to. Thanks that was a big help. Steven, Whitwell TN
Bob/Ont
04-04-2014 06:29:05
 Re: cat D7E engine balancer install in reply to Steven and Tonya, 04-03-2014 17:52:38
Your welcome Steve, The reason I said to forget the marks is the idler has an odd number of teeth(hunting gear) and it is all you can see with the cover on. If you just time up to it's mark you could be any place. If you are building the engine with all gears exposed use the marks. You will know if it's timed right when you start it and rev the engine, do that slowly the first time.
Later Bob
