TractorLinks.com
cat D7E engine balancer install
Steven and Tonya
04-02-2014 14:13:50
Just install cylinders heads, now need to install engine balancer time it to crank. Problems. there are no markings on flywheel to time balancer to. nothing to see when #1 is TDC, But on #4 TDC (180 out) there are markings that line up. What is the right way to time the thing?
Steven and Tonya
04-02-2014 16:10:42
 Re: cat D7E engine balancer install in reply to Steven and Tonya, 04-02-2014 14:13:50
update... found 2 teeth on fly wheel with 3 dots in each. Idler gear with and A on one tooth. Thats what I plan on lining up in the morning. Discover the driven gear was not in time with Idler gear. Adjusted that timing and lock down with bolt the assembly.
Old Magnet
04-02-2014 18:03:59
 Re: cat D7E engine balancer install in reply to Steven and Tonya, 04-02-2014 16:10:42
Should be two "MM" marks on the balancer drive idler and a "W" mark on the balancer drive gear.
Bob/Ont
04-02-2014 17:52:33
Forget about the marks on the gears. Take the small square cover off the top of the flywheel cover. Put ANY piston on TDC, with balancer gears not engaged, turn the weights until they are down and lock them. Push up the gears and bolt bearing into place then remove the lock bolt.
The ballancers turn at twice the speed of the crankshaft. They always are down when any piston is on TDC.
Later Bob
Steven and Tonya
04-03-2014 17:52:38
 Re: cat D7E engine balancer install in reply to Bob/Ont, 04-02-2014 17:52:33
got it installed today just as you said to. Thanks that was a big help. Steven, Whitwell TN
Bob/Ont
04-04-2014 06:29:05
 Re: cat D7E engine balancer install in reply to Steven and Tonya, 04-03-2014 17:52:38
Your welcome Steve, The reason I said to forget the marks is the idler has an odd number of teeth(hunting gear) and it is all you can see with the cover on. If you just time up to it's mark you could be any place. If you are building the engine with all gears exposed use the marks. You will know if it's timed right when you start it and rev the engine, do that slowly the first time.
Later Bob
