TractorLinks.com
Re: Cat D3 Steering Problem
dpendzic
03-31-2014 13:38:12
I am no expert but the roller cams on the end of the valve stems should be checked out---do you have dry or wet steering clutches?
screeching noises may be from no brake lining and brake band steel on brake/clutch drum
Tweeter
03-31-2014 17:38:37
 Re: Cat D3 Steering Problem in reply to dpendzic, 03-31-2014 13:38:12
There are no roller cams on the stems of these control valves. The pedal just pushes directly on the end of stem.
Bob/Ont
04-01-2014 10:54:20
 Re: Cat D3 Steering Problem in reply to Tweeter, 03-31-2014 17:38:37
Free up and lube all linkage pins outside and inside the clutch covers and see if that helps.
Later Bob
