450b jd loader
I acquired a 450B jd crawler with a backhoe attachment. I can not find the model number of the back hoe to order parts .It has a large cast piece that is almost as wide as the crawler and the backhoe can be slid from side to side to center on the work. any help will be appreciated jim
It could be a 93 or a 9300, these were the hoes that were mostly sold on 450B"s. The 93"s were older. The hoe"s on crawlers were open centered and the hoe"s on wheel tractors were closed centered.
It's a model 95A side-shift hoe. And the post about wheel tractor hoes being closed-center is incorrect. Some are open-center and some are closed-center. 95A sideshift hoe was used OEM on 350 and 450 crawler-loaders, 450 crawlers with dozers, 400, 500A, and 600 loader wheel-tractors.
95A hoe without the bucket weighs 3500 lbs. It's heavy. There was another side-shift hoe used on 1010, 2010, 3010, and 4010 wheel loaders and 1010 and 2010 crawlers. That's the model 51 and weighs 2700 lbs.
my JD 401 wheeled tractor-loader-backhoe had a side shift hoe on it. Don"t remember the hoe model number but if you look up old literature it may tell you. Prolly used the same your 450B because it was big and STOUT.
The 93 and 9300 aren't side shift hoes. I have some old brochures on 350 and 450 crawlers that only show the newer hoes without side shift.
I obtained the parts cat. for 93-95A.there was is a side shift shown but it did not look like the backhoe on the 450B that I have. I will keep searching Thanks for every ones input
