TractorLinks.com
Re: Oil pours from rear of engine on TD 6
thomaskd44
03-27-2014 09:40:03
Thank you. I will attempt that and see what happens. It may be good to clean the injector. A person told me to clean with diesel only; is that true?
Oh, does anyone know about the oil streaming out from the rear bottom of the engine. I thought it would be the rear main seal; however, when the engine is first started it does not leak much -maybe a drop every 15 - 30 seconds. When the engine is good and warm, or hot the oil streams; like a quart of oil in 3 minutes.
Could it be the oil pan at the rear that is leaking? Read the above on description and feed back will be appreciated. Thanx.
If part of a track is stuck/curved; how may one straighten it?
Thanx again
d9gdon
03-27-2014 11:36:14
 Re: Oil pours from rear of engine on TD 6 in reply to thomaskd44, 03-27-2014 09:40:03
thomaskd44 said: (quoted from post at 12:40:03 03/27/14)
Thanx again
Drive it into some standing water, it'll loosen the rust in the pins after driving it around a while. Works better than anything else.
I can't help with the oil leak, I'm not familiar with those engines.
Getting the injector rebuilt would be best, IMO.
This post was edited by d9gdon at 11:39:00 03/27/14.
thomaskd44
03-28-2014 21:24:37
 Re: Oil pours from rear of engine on TD 6 in reply to d9gdon, 03-27-2014 11:36:14
Thank you for your advice. I remain obliged.
