TractorLinks.com
Re: jd 450c three point hitch
Stick welding
03-26-2014 23:26:12
You'll need a heavy duty box blade behind a 15,000 lb+ crawler! For doing an MX track it would be slow. You also have to consider undercarriage wear going around a track usually about a mile long and you might have to go around 3 or 4 times. I know this because I have an MX track myself and a similar size Cat 931B loader with quick attach backhoe. Depending on your soil, the crawler would be good for shaping or ripping hard packed ground. For general grooming a tractor would be better and a lot less wear. I made a heavy duty groomer for a 3 pt. hitch out of a huge 14" H beam with 15 backhoe teeth adapters welded on so the teeth are easy to replace.
