Yesterday's Tractor Co.
Shop Now View Cart
TractorLinks.com
Help find serial number on D7e
Steven and Tonya
03-25-2014 16:09:24
I have a D7e build date 12/1967. I have been all over the block looking for the serial number. Saw where Hector suggested looking at the back of block about where the 2 rivet holes are and I still find nothing. Block casting #4S8840, and I am sure its a D339 4 cylinder. I found rebuild kits from Clevite, Blakesreman, Partsuplycorp. But with out the serial number I am dead in the water. Any Help be most appreciated. Steven, Whitwell TN, 423-364-
1411
jm.
03-26-2014 17:27:29
 Re: Help find serial number on D7e in reply to Steven and Tonya, 03-25-2014 16:09:24
Steve is this an military unit. That unit serial is right under the winch top left bolt.
Steven and Tonya
03-27-2014 12:58:16
 Re: Help find serial number on D7e in reply to jm., 03-26-2014 17:27:29
Hot Dog I found it! the unit number. Cleaned off layers of filth and paint and sure enough it was stamped in the rear under that bolt. Thanks
d9gdon
03-27-2014 13:26:52
 Re: Help find serial number on D7e in reply to Steven and Tonya, 03-27-2014 12:58:16
There won't be an arrangement number on that machine. Use the serial number that you found to order parts for the engine.
gemdozer
03-26-2014 08:04:36
Maybe you could find a other serie number on bottom block motor on the lipp near the oil pan on same side poney motor
jm.
03-25-2014 16:22:29
Steve walk up to the rear of the tractor, take your left hand stick it straight out about waist high. The number is on a metal tag right there in front of your hand. On the rear housing top left corner. Now this is the unit serial number not the engine.
Steven and Tonya
03-25-2014 19:51:59
 Re: Help find serial number on D7e in reply to jm., 03-25-2014 16:22:29
Ah there is a giant Hyster wench on the back. Tho there is a tag in the side of the wench. Thanks
Steven and Tonya
03-25-2014 19:54:53
 Re: Help find serial number on D7e in reply to Steven and Tonya, 03-25-2014 19:51:59
Arrangement number for engine is what i think i'm looking for.
