Bobcat S100 Changing Coolant
LonM
It is time to change the coolant in our S100, with the Kubota V1505 4-cylinder diesel engine. The operators manual says to open the drain valve on the block, but I cannot find any sort of valve to open. Does anyone know where this may be? I have lifted the cab to check the "left" side of the engine with no luck either. I am sure I am missing the obvious but would appreciate some direction. Thanks for any help!
Lon
