mc steering clutch
Is their any adjustment on the pressure plate?
put all back together with good used parts but
clutch is slipping.don"t want to take apart again. any info will help
THANKS JOE
AFAIK the only adjustment is to get all the release fingers to the same height. JD made a gauge. Lavoy sells copies of the gauge. JDCrawlers dot com.
Bryce
If you tear it apart to adjust fingers you may want to check spring tension also!
