JD 350 blade lift cylinders...
2x4
need to find a hydraulic blade lift cylinder for old straight JD 350 dozer. Anybody know any junkyards that might have one or both? Any idea of price they might ask for one? Would one off a 1010 work? I expect gas or diesel would use the same cylinder.
No such thing as a 350 dozer. You've got a 350 crawler with a dozer that has its own model number. Depends if it's an outside blade dozer, inside 4 way, inside 6 way mechanical or 6 way inside full hydraulic. A inside manual 6 way dozer on a 350 is a model 6300 and it uses 3" X 12.1" lift cylinders. One all hydraulic inside 6 way dozer for a 350 is the 6305 with 3" by 12.1" lift cylinders. 6 way inside hydraulic dozer on a 1010 is a model 612 and uses different cylinders.
