TD6 drive coupling bolts
Anonymous-0
I took the steering clutches out of my TD6 yesterday, it wasn't nearly as bad as everyone told me it would be. Almost every repair I've ever done on a skidloader was worse than this. My problem is some of the bolts that hold the drive coupling in, You Know the ones that are hard to get to, are broken off. The splines in the coupling are definately worn but I think they will be OK. Does anyone know where I might be able to buy these yet, or does anyone have a set laying around that they would part with? Thanks in advance!
Bolts are pretty generic, unless they are a special, non-standard bolt, you can get bolts from your local hardware store, Fastenall, or online from McMaster-Carr or MSC Industrial Supply.
You can tell yourself you are a good mechanic or have a lot of luck. Tat is normally a tough job on an old loader. You can get the grade 8 bolt at napa. I always went back with all new bolts.
The bolts I am looking for are a shouldered, fine thread, grade 8 with the holes in them for the locking wires. I already checked with local hardware stores and auto parts stores with no luck.
Well in that case I will go to digging. When I sold the salvage yard I kelp a lot of the new small parts. Should be some of those bolts here at the farm I just have to find them. Not sure if th6 & 9 are the same.
jm, let me know if you find some, The TD6 has 3/8 fine thread bolts but I'm not sure about the TD9 either. I really appreciate the help.
