Need any info on skid steer mod. 40A made by White
Dana M
New User
Can't seem to find any information (operators manual)about a skid steer I just bought, made by White, model says 40a and says Beaver on the seat back. Need any help available. It does have a Wisconsin V4 gas engine, if that helps.
I think I have found out that this skid steer was made by Erickson since similar design. The Ford CL-40 is the closest machine I have found and I have been told it was made by Erickson, but it is a 70"s machine and I have what appears to be one made in the 60"s. If it helps it is light red (or dark orange) in color and I need to replace an axle shaft that is snapped off at the sprocket end. It has ten splines and measures 1.5 inches in diameter at the splines. The sprocket is 60 tooth but is not damaged.
