mjsnodgrass
I have a 2WD Case 580 E backhoe. the left rear brake has a high brake pedal and the brake drags. the right brake has a low pedal, but the brake seems to work ok. I pulled the dash apart to check brake fluid, but it appears the master cylinders are supplied by the hydraulic system. I followed the brake lines, and under the dash near the bottom of steering column there appears to be a equalizer valve of sorts. I am in the process of pulling the floorboards to see if I can figure out how to adjust the high brake. anyone have any suggestions as what my problem could be? thanks
