Yesterday's Tractor Co.
Shop Now View Cart
TractorLinks.com
Re: Cat D7 3T #16602
goldminer7759
02-22-2014 05:14:46
Billy,
Thank you for the additional information! What part of NY are you? Just curious as my father-in-law is in the Buffalo area.
Billy NY
02-25-2014 20:59:36
 Re: Cat D7 3T #16602 in reply to goldminer7759, 02-22-2014 05:14:46
I dug out a spare Delco-Remy starter motor. This is a more modern one, nomenclature is stamped into the cast housing and reads as follows:
1107399 6 M 12
DELCO-REMY U.S.A
3 A
The gear in the housing is straight cut, it should bolt right in place after the cover is removed. Gear will mesh with clutch flywheel.
Use care when fastening and tightening the starter housing to the clutch housing, the flange edges on the starter housing can break the corners off at the bolt holes. The starter is heavy, might be best to bolt housing first, tighten down. Given the age of these things, I'd also recommend using an appropriate tap, thread chaser on the holes, always good measure, that ant anti-seize. The spring loaded switch on the starter motor operated by a lever, will seize if left in the elements, best to try and keep under cover if possible, lubed etc.
Billy NY
02-23-2014 07:04:20
I'm just east of Troy, I've yet to get a part number off the starter will try and post back today.
Copyright © 1997-2015 Yesterday's Tractor Co.
