Yesterday's Tractor Co.
Shop Now View Cart
Re: Concern with my TD 6 1947-9...white smoke.....and
02-15-2014 19:01:04
Thomas, once you get the valve cover off, check that the starting valve is closing on the bad cylinder. If that valve does not seal when you switch to diesel, you will probably get the symptoms you are seeing. If it runs without a miss on gas, then it probably is not the exhaust valve. If valve(s) look OK, then it's probably the injector. Al
