Re: Concern with my TD 6 1947-9...white smoke.....and
02-15-2014 14:19:12
Operating on gas start up; there is no white smoke. Only after I have switched to diesel. And, like stated; when I disconnect the injector, there is no white smoke. When I connect the injector, white smokes emits. That tells me that when fuel is injected into the cylinder the exhaust valve is not closed and the raw/unburned fuel goes out the exhaust. Am I correct? One other important thing: when disconnecting the injector the same r.p.m. does not change; when disconnecting the other three cylinders -on at a time- they drop in r.p.m. So, what is happening?
02-15-2014 20:17:07
 Re: Concern with my TD 6 1947-9...white smoke.....and in reply to thomaskd44, 02-15-2014 14:19:12
If there are no abnormal noises from the valve train when running, get this engine good and warm before taking anything apart. Use a small amount of diesel, like a few gallons with a rich mixture of a good diesel fuel lubricant, from any tractor dealer, and get the engine up to operating temp at high idle, you may be surprised how some things fix themselves with lube and heat. I have had these IH gas start diesels, create white smoke after a lengthy storage, only to respond to lube and heat. The first thing, change oil in the pump.
