Yesterday's Tractor Co.
Shop Now View Cart
TractorLinks.com
Re: Concern with my TD 6 1947-9...white smoke.....and
AJB-830
02-15-2014 08:16:50
Thomas, Yes the No. 1 cylinder is the one in the front by the radiator. Then the timing would be 1-3-4-2. The cap on your injection pump is to add motor oil to the pump. Since you just got your tractor running, I would drain all the oil out of the injection pump and then re-fill it up to the level plug. This is a 1/4 inch plug up about 2 inches above the drain plug. You can use the same oil as what you put in the engine. If the pump was leaking, you might find that some diesel will drain out with the old oil. As far as the white smoke, it could be a bad injector or a valve not closing. Good Luck. Al
Copyright © 1997-2015 Yesterday's Tractor Co.
