TractorLinks.com
4 in 1 Bucket
WayneB
02-15-2014 06:43:21
Mounting a 4 in 1 bucket on a 1955 Allis Chalmers HD-5G. What is the best way to rig the extra line needed for the 4n1 bucket cylinders?
8V71
02-16-2014 08:32:56
 Re: 4 in 1 Bucket in reply to WayneB, 02-15-2014 06:43:21
The valve with extra spool might be a better option.The only problem with most power beyond set ups is you cant use the bucket clamp cyls at the same time as an other functions.
WayneB
02-16-2014 11:56:50
 Re: 4 in 1 Bucket in reply to 8V71, 02-16-2014 08:32:56
So far I am only finding 25GPM setups.
I have a 4 lever backhoe cylinder with 2 outrigger controls ON-HAND off a Dynahoe. Too easy to pull the extra handles. Certainly will handle the volume. Used it, so I know it is good.
NCWayne
02-15-2014 20:47:10
Running a different valve with an extra spool like your talking about would work great. The alternative would be to use the current valve with a power beyond valve, and a single spool valve for the extra function.
WayneB
02-16-2014 08:08:50
 Re: 4 in 1 Bucket in reply to NCWayne, 02-15-2014 20:47:10
I either have to replace the current valve body or put a gasket on it. Minor weep/leak.
My thinking is the lift spool valve should have a float feature, for the bucket blade.
WayneB
02-15-2014 17:35:14
Second question: What is the GPM flow, if I replace the current valve set with one with more levers.
