Yesterday's Tractor Co.
Shop Now View Cart
TractorLinks.com
Re: Concern with my TD 6 1947-9...white smoke.....and
Diydave
02-15-2014 05:09:55
Sounds like you have a bad injector, or something out of order in the valve train, at that cylinder. Check the valve adjustment, push rods, do a wet compression check, etc. As for the cap on the injector pump, it might be for adding motor oil to the injector pump. Some older pumps were independently lubed, meaning they had their own oil reservoir, cap and drain plug, separate from the motor's lube system. Don't know if this is the case with your IH...
And I would accept Dick's definition of #1 cylinder.
