TD-14A Hydraulic Leak
thebunns
While plowing snow today I noticed a hydraulic leak coming from around the top of the reservoir. It sprayed the hood and everything around the front of the tractor. I'm going to attempt to confine the spray & add fluid as necessary to try & make it until spring. Looking ahead, to remove the reservoir do I have to remove the ROPS first or does unbolting the brackets under the front of the tractor allow the assembly to drop away from the two pipes coming from the roof down to the front end of the tractor?
Vic
