Yesterday's Tractor Co.
Shop Now View Cart
Kevin Wright
02-12-2014 10:06:09
took both lift cylinders loose at the chrome end, with the engine off and tilt control centered, you cannot move the ram in or out. did this one at a time, with the cylinders off, the control valve will suck the rams in VERY SLOW. out works just fine....
Roy Suomi
02-12-2014 20:27:46
 Re: GEHL HL4400 BUCKET GOES DOWN BUT NOT UP in reply to Kevin Wright, 02-12-2014 10:06:09
I'm not familiar with these machines, but, by what I read maybe you have a problem with lift checks or relief valves.. Lift checks are in backhoes that keep a function from leaking down when a valve is first shifted so a boom or other function doesn't drift down as you build full hydraulic pressures to move a function upward.. Is the valve actually moving all the way in the slow direction ?? Or is it only partially opening ??
