thomaskd44
Hello
I have a [b:6b23697ff6]1949 TD 6[/b:6b23697ff6] international dozer crawler -just purchased.
I am unable to start the engine on gas. I have electricity, magneto, and when I pull the lever back and attempt to start the engine it won't start. However, there is electricity; there is fuel. The firing order 1-3-4-2. When a pour some gas in the intake the engine will run until the gas is used, then the engine stops.
It is clear to me; the engine is not getting gas through the intake to the engine. With everything working; electricity, fuel, could the only problem be the valve(s) (how many are there) in the intake not opening? I don't know where else to go, and if that is the case, how do I correct it? What do I have to do? Anyone with knowledge explain, I will remain appreciative.
