TractorLinks.com
Re: Cat IT28 running on 2 cylinders
RodInNS
02-08-2014 20:46:10
That does add some variables to the mix... If you had the ability to do a compression check on all 4 cylinders and see if they're within 5-10% of each other that would be a big help in knowing where the problem is. If the comp checks out then you'd look hard at those two cylinders on the pump provided the injectors check out.
Rod
