Yesterday's Tractor Co.
Shop Now View Cart
TractorLinks.com
Re: Cat IT28 running on 2 cylinders
Firemanjohn
02-08-2014 13:54:21
Thank you everyone. I was skeptical on the head gasket with no oil water mix. Either way we will see. Is there any other tell tale sign I should look for with the blown fire ring?
RodInNS
02-08-2014 14:14:34
 Re: Cat IT28 running on 2 cylinders in reply to Firemanjohn, 02-08-2014 13:54:21
If it's bad enough you'll hear it farting or squalking. It'll also erode the deck if you run it long like that...
The only other thing that would immediately come to mind with this thing.... if it is a Cat pump on it... there could be a problem with the plungers or delivery valves in an inline pump. If it's got a CAV rotary pump then the pump will most likely not be the problem.
Rod
