TractorLinks.com
Re: JD 350 crawler brake/steering clutch adjustment
jdemaris
02-06-2014 05:37:46
350 and 350B have NO oil in the steering clutches. The lever has to be adjusted so as you pull it back - the steering clutch disengages BEFORE the steering-brake grabs. Sounds like you've got your brake on while the clutch is still trying to power it. When all is right - you should be able to put the crawler on a steep hill facing up - put it in forward, let the levers go - and then as you are moving forward- you should be able to pull them back to a point the crawler will roll backwards. Pull back a little more and it will stop thanks to the brakes.
