Yesterday's Tractor Co. The Right Parts, Right Away
Tractor Manuals
TractorLinks.com
Enter your email address to receive our newsletter!
subscribe
unsubscribe
What to buy Case 450c or Deere 450G
JohnDeereJimOhio
02-01-2014 07:14:37
174.231.2.121
What to buy? Both in great shape, case has 3100 hours deere has 3900 hours both undercarriages are over 80% both are bare back with 6 way blade, both are one owner machines. Asking 18500 for deere and 16,800 for case.
[Reply]   [No Email]
dej(Jed)
02-04-2014 05:56:39
141.189.113.1
 Re: What to buy Case 450c or Deere 450G in reply to JohnDeereJimOhio, 02-01-2014 07:14:37
Man I don't know. They are both pricy. You can get a darn nice Cat for that kind of money. If I had to pick it would be the Case. Those JD are bad news.
[Reply]  [No Email]
The tractor vet
02-02-2014 08:50:26
75.19.125.103
Well as for me i like the Deere's over the Case. and to me a 450 is and OK size for light dozing and grading . Now the 650 Deere is a great dozer for size and power IMHOP as long as you add either a winch or four slab weights to the rear . That balances them out just perfect and they will move dirt push trees and grade super . With out the weight on the back they are nose heavy . The 450 Cases to me are way to light and to jerky .
[Reply]  [No Email]
marloweg
02-01-2014 19:34:44
70.194.129.25
have both Case hands down not as big but better machine
[Reply]  [No Email]
mab570diesel
02-01-2014 16:18:36
76.6.162.148
 Re: What to buy Case 450c or Deere 450G in reply to jm., 02-01-2014 07:14:37
Quoting Removed, click Modern View to seewhat about all the steering clutch issues?
[Reply]  [No Email]
Bill Lisbon
02-01-2014 16:11:14
69.89.162.192
Buy the John Deere, it is a much better built machine. The 450 case is a smaller machine, a little bigger than a 350 Deere. I work on equipment for a living and I've seen machines front to back, inside and out, and John Deere is a better machine than the Case.
[Reply]  [No Email]
Case Nutty 1660
02-01-2014 15:56:11
75.127.24.27
here where I am there are 10 CASE dozers for that size range than JD, the 450 is a very good dependable machine I have run and been around them since 1966, we traded for several JD units back in the day the 2010 units were not bad or the 350's the 450 here anyway seemed to have steering clutch issues, these were dozer and side boom units we have very few with loaders on them here, also the 450's we sold were used in the oilfield, some of the hardest duty you can put a dozer thru, abuse is a daily thing
[Reply]  [No Email]
Bob Bancroft
02-01-2014 13:53:51
67.142.162.22
Have you, or can you run both? The only Case I was ever near enough to run a little had the two little levers for track control- Very different, to say the least! I wanted pedal steer, full power shift, torque converter drive, and was able to find all that. So I say buy whichever one you prefer to operate.
[Reply]  [No Email]
JohnDeereJimOhio
02-01-2014 12:36:50
174.255.50.169
Both have had undercarriage redone
[Reply]  [No Email]
jdtractor
02-01-2014 10:36:49
67.140.14.204
I say go with the deere . case is wanna be construction equipment. They are cheaper because they are less machine . Ive seen it and run them. U cant beat cat or deere u get what u pay for. Ive run dozer all my life. I own a DEERE and and it will out work a case double time.
[Reply]  [No Email]
mab570diesel
02-01-2014 10:54:22
76.6.162.148
 Re: What to buy Case 450c or Deere 450G in reply to jdtractor, 02-01-2014 10:36:49
i doubt that sounds like you just have a hard on for anything that says deere on it with no knowledge of dozers we are speaking of don't make it good just means you're paying for the name had new deere equipment much rather have other brands better performance and better price deere awfully expensive to work on
[Reply]  [No Email]
jdtractor
02-01-2014 15:38:30
67.140.14.204
 Re: What to buy Case 450c or Deere 450G in reply to mab570diesel, 02-01-2014 10:54:22
I don't have a hard on for deere. I do know that Ive done heavy dirt work all my life with heavy equipment, such as pipeline, and heavy highway dirt jobs. U seldom see case out there doing heavy dirt work, the others I run equipment with don't like them either, there weak and gutless compared to the other brands. When I do see case they are doing light work lite clean up and easy work. where there is dirt to be moved u had better start early and figure on a long day. BEEN there and as I said earlier seen it.
[Reply]  [No Email]
Case Nutty 1660
02-01-2014 17:25:16
75.127.24.27
 Re: What to buy Case 450c or Deere 450G in reply to jdtractor, 02-01-2014 15:38:30
they are far from gutless, for their size they have plenty of power, I too have run and used them for 45 years, the JD units are good as well but lets be real gutless I really doubt you ever ran one much if any
[Reply]  [No Email]
jdtractor
02-01-2014 18:32:26
67.140.14.204
 Re: What to buy Case 450c or Deere 450G in reply to Case Nutty 1660, 02-01-2014 17:25:16
I think you are the 1 that's windy. Ive got more hours then your years running dozers and I stand by what I said they are OVERRATED.I m not going to argue with someone.U can have your opinion and I have mine I will stick with JOHN DEERE.
[Reply]  [No Email]
Stick welding
02-01-2014 16:37:39
96.53.210.246
I've heard operators say the Case is a far better machine too. 450's of any make aren't used for heavy work regardless, so I don't know what you're comparing them too. When there's a lot of dirt to move, you see Cat and Komatsu. Would be nice to know what year each machine is. I think a Case 450C is older than JD 450G. The JD's also had a choice of direct drive or torque converter transmission. Also don't put a lot of faith in what an hour meter says.
[Reply]  [No Email]
Stick welding
02-01-2014 10:18:34
96.53.210.246
Who's saying the undercarriage is 80%. Have they been changed already? I only ask because the hours would indicate a new chain close to worn out. 80% would indicate they're already replaced. Case is usually lower priced but I think the Case might be a little older too.
[Reply]  [No Email]
john730d
02-01-2014 08:15:51
208.73.228.5
No brainer
Case, hands down. Better machine and will run circles around the Deere.
By the way, I own John Deere and Case in both ag and construction models.
[Reply]  [No Email]
mab570diesel
02-01-2014 07:49:05
76.6.162.148
i'd go for the case cheaper in price and better machine
[Reply]  [No Email]
[Options]  [Printer Friendly]  [Posting Help]  [Return to Forum]   [Add a Reply]
TRACTOR   PARTS TRACTOR   MANUALS
Same-Day Shipping! Most of our stocked parts ship the same day you order (M-F).  Expedited shipping available, just call!  Most prices for parts and manuals are below our competitors.  Compare our super low shipping rates!  We have the parts you need to repair your tractor.  We are a Company you can trust and have generous return policies!   Shop Online Today or call our friendly sales staff toll free (800) 853-2651. [ More Info ]
Copyright © 1997-2014 Yesterday's Tractor Co.
