TractorLinks.com
Re: MF34A Industrial Loader control valve
RICHNY
01-31-2014 06:19:38
I have a MF30E with the same loader. The engineering drawing for this assembly shows a separation (assembly point) at the base, but I wouldn't separate it if I were you. The side scematic shows flow through the valve from the loader hose to the opposite spool. If the oil has water in it, its probably freezing in the valve port from the exposed hose line. There is NO DRAIN. I would change to a thinner oil.
mattwillson
01-31-2014 16:12:54
 Re: MF34A Industrial Loader control valve in reply to RICHNY, 01-31-2014 06:19:38
Permatran 821 is the ONLY oil to use, unless you want to rebuild the shuttle AND have really crappy hydraulics. frequent oil changes keep the water condensation out. Probably why MF isn t a popular construction machine. BTW I still like my 30B alot.
mattwillson
01-31-2014 16:12:20
Permatran 821 is the ONLY oil to use, unless you want to rebuild the shuttle AND have really craooy hydraulics. frequent oil changes keep the water condensation out. Probably why MF isn t a popular construction machine. BTW I still like my 30B alot.
