Yesterday's Tractor Co. Affordable Parts, Just in Time
Tractor Manuals
TractorLinks.com
Enter your email address to receive our newsletter!
subscribe
unsubscribe
MF34A Industrial Loader control valve
MKinON
01-30-2014 21:52:33
69.158.115.176
I've tried this on the MF forum and no luck so far, but maybe here ...
Wondering how to get the caps off at the bottom of the loader valve body. Boom lift function won't work unless the cap under that valve is heated. Sadly, we currently have no heated shop to park it in and it's needed for snow clearing. With 2-3 minutes of the heat gun pointed at it, the action is fully restored. We figure there must be water accumulated down there and thought the cap could be removed and dumped. However it won't come loose from the valve inside and I'm leery of pulling the valve out completely. Parts diagram is unclear but looks like there might be a set screw at the bottom that holds the valve, though it didn't look like there was one when looking at the cap itself. The cap looks like a 3 piece part. Do the body parts thread together? Is there an allen head screw in the bottom that ties it together? The complete valve section doesn't easily want to drop out with the cap and I'm afraid of something getting out of place further up in the bore if I do pull it out completely. It's a hard push to get it back in when just dropped down partially. Hopefully the pics will upload. Thanks for any and all help. MK
[Reply]   [No Email]
MKinON
02-10-2014 03:54:30
174.91.103.10
 Re: MF34A Industrial Loader control valve in reply to MKinON, 01-30-2014 21:52:33
Thanks for the advice. We'll have to try and do something as the lift spool just won't work if it's below freezing. MK
[Reply]  [No Email]
chuck41
01-31-2014 06:36:03
67.4.219.106
Those small tips on the bottom of the cap assy's
are actually filters. We sold these and would take these caps off.The filter p/n is 1086 541m1
but those caps will come off. I no longer have a
service manual but should come off by removing
those sockethead screws. Something is "jammed" or
?. I should have said that the filters are inside
those tips on the caps. Chuck
[Reply]  [No Email]
RICHNY
01-31-2014 06:19:38
71.167.62.227
I have a MF30E with the same loader. The engineering drawing for this assembly shows a separation (assembly point) at the base, but I wouldn't separate it if I were you. The side scematic shows flow through the valve from the loader hose to the opposite spool. If the oil has water in it, its probably freezing in the valve port from the exposed hose line. There is NO DRAIN. I would change to a thinner oil.
[Reply]  [No Email]
mattwillson
01-31-2014 16:12:54
50.101.98.24
 Re: MF34A Industrial Loader control valve in reply to RICHNY, 01-31-2014 06:19:38
Permatran 821 is the ONLY oil to use, unless you want to rebuild the shuttle AND have really crappy hydraulics. frequent oil changes keep the water condensation out. Probably why MF isn t a popular construction machine. BTW I still like my 30B alot.
[Reply]  [No Email]
mattwillson
01-31-2014 16:12:20
50.101.98.24
Permatran 821 is the ONLY oil to use, unless you want to rebuild the shuttle AND have really craooy hydraulics. frequent oil changes keep the water condensation out. Probably why MF isn t a popular construction machine. BTW I still like my 30B alot.
[Reply]  [No Email]
[Options]  [Printer Friendly]  [Return to Forum]   [Add a Reply]
TRACTOR   PARTS TRACTOR   MANUALS
Same-Day Shipping! Most of our stocked parts ship the same day you order (M-F).  Expedited shipping available, just call!  Most prices for parts and manuals are below our competitors.  Compare our super low shipping rates!  We have the parts you need to repair your tractor.  We are a Company you can trust and have generous return policies!   Shop Online Today or call our friendly sales staff toll free (800) 853-2651. [ More Info ]
Copyright © 1997-2014 Yesterday's Tractor Co.
