JD 350C CRAWLER
#1 make sure the pump is still turning. The splined driveshaft parts in front wear out.
#2 make sure your return filter is clean. If your machine is below serial # 354079, it's hidden under the hydraulic reservoir cover. Later Cs have spin-on filters outside where you can see them.
