Yesterday's Tractor Co. Restoration Quality Tractor Parts
Tractor Manuals
TractorLinks.com
Enter your email address to receive our newsletter!
subscribe
unsubscribe
D-2 cat
BW62
01-26-2014 21:18:21
64.250.219.234
D2 cat sat for a lot of years with empty diesel tank. Pony motor runs, but can"t get diesel primed. Have fuel from tank to pump, but nothing at injector lines. Is there anywhere between main fuel line and injector pump to bleed? Also how hard is it to replace governor belt on pony motor?
[Reply]   [No Email]
gemdozer
01-27-2014 06:05:40
70.48.84.254
 Re: D-2 cat in reply to BW62, 01-26-2014 21:18:21
You could removed the injection pump side cover if the rack and small pump are free
[Reply]  [No Email]
TomA
01-27-2014 00:09:11
66.81.241.31
You must bleed 4 individual bleeders behind each injection pump. Takes a special wrench. Also two bleeders on filter tower, one below filters and one above. If you can afford it fill tank plumb full and open bleeders, it will prime overnight by gravity.
[Reply]  [No Email]
Randy Shoe
01-26-2014 21:23:17
70.208.23.41
I think I would try cracking the injectors and putting air to the fuel tank to force fuel to filters and injectors.
[Reply]  [No Email]
BW62
01-26-2014 22:22:31
64.250.219.234
 Re: D-2 cat in reply to Randy Shoe, 01-26-2014 21:23:17
Thanks. Did that and got fuel pressure to come up part way but gave up when not a drop came out of injector lines. Just covered fuel cap hole with hand and rag, so maybe didn't get enough air pressure on lines.
[Reply]  [No Email]
dpendzic
01-27-2014 06:30:06
24.184.14.235
 Re: D-2 cat in reply to BW62, 01-26-2014 22:22:31
you want about 5 psi on the tank pressure--an old inner tube section with the fill valve and a clamp around the fill neck works good. are the fuel filters and housing dirty and clogged? Check those bleeders on the fuel filter housing to see if you have flow there.
[Reply]  [No Email]
[Options]  [Printer Friendly]  [Return to Forum]   [Add a Reply]
TRACTOR   PARTS TRACTOR   MANUALS
Same-Day Shipping! Most of our stocked parts ship the same day you order (M-F).  Expedited shipping available, just call!  Most prices for parts and manuals are below our competitors.  Compare our super low shipping rates!  We have the parts you need to repair your tractor.  We are a Company you can trust and have generous return policies!   Shop Online Today or call our friendly sales staff toll free (800) 853-2651. [ More Info ]
Copyright © 1997-2014 Yesterday's Tractor Co.
