Any help would be MUCH appreciated!
This is what is happening. No forward or reverse in any gear, cold or warm. It doesnt even try.
what I've done:
Had the fluid coupling rebuilt (torque converter).
Tested the output of the hydraulic pump that powers the reverser.
it put out 1700 lbs all day. It also pumped the volume of oil it should.
checked the pressure at the control valve on the top of the reverser. It was in spec.
checked and got almost NO oil pressure at the port on the bottom of the reverser. I cant remember the name of it, but its the one thats in the circuit that controls the forward and reverse clutch packs.
like I said, any help would be appreciated.
Thanks for looking!
what I've done:
Thanks for looking!
