250 John Deere
jcsinga
Trying to pull a 3029 JD engine from a 250 JD skid steer. I have 4, 5/8" bolts out of the hydraulic pump drive one on each corner but cant get any separation. More/other bolts? Pump drive hanging up inside? Thanks for any info.
The pump is held to the bracket it sits on with four 3/8 bolts coming up from underneath,try removing the two bolts on the pump flange as well as the four under the bracket and see if it will part,like you said it may be hung up on the coupling,
AJ
Thanks for the reply AJ. I got it out but the pumps and bracket came out with it. There are an additional 4 bolts around the bottom of bellhousing that would be next to impossible to get out while in the machine. IDK mabye if the machine didnt have 8" of oil, grease, chicken crap and who knows what else in the bottom.
