TractorLinks.com
Re: JD 450 power steering ?
Roy Suomi
12-20-2013 13:28:08
Add oil to it... It isn't gonna hurt.. It will either leak externally on loose lines , rubbed thru lines , leak out of cylinder seals under the seat or leak thru the pump shaft seal into the engine.. If the engine oil level goes up a good bit , the shaft seal is leaking into the crankcase via front cover to sump.. When it's operating correctly , there will be a slight vibration felt in the steering levers when you pull on it..
lti
12-20-2013 14:14:45
 Re: JD 450 power steering ? in reply to Roy Suomi, 12-20-2013 13:28:08
Thanks Roy; What if it does all that, except ur last line" When its operating correctly"....lol. Thanks again..
