Yesterday's Tractor Co.
Shop Now View Cart
TractorLinks.com
Re: TD 14 carb will not turn up engine rpms. up
n9lhm
12-18-2013 13:02:14
They don't run real fast at start. You should be able to maximize RPMs with the choke as it warms up, after it has run for a minute or so it should show full rpms with the choke fully open (800-1000 RPM or so). The throttle disc at the output of the carb can be set to change the idle RPMs, I believe the book spec is 7/64" clearance between the disc and the carb body. If it still needs part choke to run best after two minutes or so there is probably still a restriction in the carb jet. E-mail me back if you want to talk more. Brian
Copyright © 1997-2015 Yesterday's Tractor Co.
