TractorLinks.com
Re: clark bobcat 610
IowaJohn
12-14-2013 20:58:28
When mine does that it's a leak somewhere between the valve and the variable sheave on the engine. I've had O-rings on the cylinder inside the sheave start leaking and cause it to slow, it's hard to see that but try and look between the sheave and the engine to see I there is any fresh oil. It also could be o-rings in the valve that are worn and letting oil by. If it moves good at high speed and the clutches aren't slipping then they're fine. I'm pretty sure it won't be in the chain cases. All that's in there are sprockets,chains and the wet clutches you engage when you move the levers.
don kain
12-15-2013 15:12:21
 Re: clark bobcat 610 in reply to IowaJohn, 12-14-2013 20:58:28
thank you Iowa John for your help and info.As posted its working again.Why,dont know.I am going to drain the hydraulic fluid . put fresh fluid in after changing the filter and go from there. may take awhile to post after waiting and trying it awhile to see if problem reoccurs,thank you for your help and interest
