Re: JD450 steering clutches
Roy Suomi
Drop one friction clutch disk into the drum then drop in the splined center hub engaging the splines on the drop-in hub. Then build from there.. Alternating steels and fibers.. You will need to put both shafts together and engage splines into drum and hub to keep all lined up before tightening pressure plate bolts... R.S.
